First attempt at a robotic arm! Suggestions for base?
(1/2) > >>
OK, so here's my base thus far!
Anyway, the problems I've been facing with this base is that it's all wobbly once I start attaching the arm!  People suggest I install rollers, but I don't have any idea how to actually do that!  I'm doing small scale here (1/8" thickness), any suggestions?  Or better yet, a direction?
you should install rollers because otherwise your arm it will not has balance , check out the shematics ( i am not good at paint  :P )
Maybe a Lazy Susan bearing.
Wow!  I am going to check that lazy susan bearing out!  Thanks!
You could use a bigger servo horn... or perhaps a attach a support plate to the servo horn so it has more area under the base, and takes up force more evenly from the top
[#] Next page
