Author Topic: I am making $50 robot  (Read 1278 times)
Offline SHREYANSH JAINTopic starter
« on: July 11, 2013, 06:52:17 AM »
I am making $50 robot and little part is left but there is a great problem in this where i live , hitec HS-311 servo are not available but different servos are available,can i use another servo motor to make it and what changes should i make to make it work.Please help me i almost done it.
Thanks... :)
Re: I am making $50 robot
« Reply #1 on: July 11, 2013, 10:13:42 AM »
Yes, you can use another servo that has similar characteristics. Go by similar size and weight and voltage rating and you'll probably do OK.
Offline Conscripted
  • Helpful? 10
« Reply #2 on: July 14, 2013, 08:27:22 PM »
Good luck with your $50 robot. Many of us here have built it.
Servos all work pretty much the same. The only thing you might have to change are the steps to convert the servo to continuous rotation. Google can help with the servo modification. Let us know how your build goes and make sure to post pictures.
Conscripted
