Author Topic: DC-DC Converters  (Read 1534 times)
Offline sherbyTopic starter
DC-DC Converters
« on: July 13, 2013, 03:48:04 PM »
Is there any DC-DC Converter for step up, ie low to high voltage to convert 9v to 12v?
I know about 7805 and lm317, but they convert from high to low.
Thanks for the help!'
also i came across LM2622, is there any guide on using it?
« Last Edit: July 13, 2013, 03:50:03 PM by sherby »
Offline billhowl
  • Helpful? 32
Re: DC-DC Converters
« Reply #1 on: July 13, 2013, 05:39:19 PM »
DC-DC Converter for step up is called boost converter
One of it is LM2577
http://www.ebay.com/sch/i.html?_ipg=200&_sacat=0&_from=R40&_nkw=lm2577&_sop=15
« Reply #2 on: July 13, 2013, 05:54:17 PM »
Thanks for the reply, also i had a question regarding current.
If the i/p is 9V 1A, so i am guessing with the pot i can change outpt to desired(this case 12v), then what would be the current at the o/p?
will it just be calculated from power conservation P=VI, so 9*1=12*outcurent
Offline billhowl
  • Helpful? 32
« Reply #3 on: July 13, 2013, 06:28:22 PM »
The Boost converter had efficiency about 80% to 90%
calculated from power conservation P=VI, so 9*1=12*outcurent * 0.8
« Reply #4 on: July 13, 2013, 07:22:13 PM »
Thanks you guys for all the help!  :)
« Reply #5 on: July 14, 2013, 02:04:05 PM »
FWIW, Pololu.com has a nice selection of step-up, step-down, and even step-up-down converters for use on robots. Some of them have up to 95% efficiency under the right conditions.
