gear measurement for servo motor
<< < (2/2)
am i safe to say that the diameter of the shaft is 5mm?
That's not a shaft, that's a spline. And, looking at your ruler, it looks like the outer diameter of the spline is about 5.5 mm.
I think the best thing you can do is to get a round servo horn that is known to fit, and then put (glue? expoxy? screw?) a gear of some sort onto that horn. has a number of round servo horns for 23T, 24T and 25T splines. Do you know which of those your GWS servos are using? (Google ought to know, at least)
Ahh...a gear output instead of a horn. ok.
Start googling and looking at any company that sells servos and Robot parts. I recalled one of them have gears that fit onto servo splined shafts.
Also be sure to check with the companies that advertize on this web site (on the right side of this screen).
[*] Previous page
