Author Topic: problem with $50 robot  (Read 1408 times)
Offline SHREYANSH JAINTopic starter
« on: August 06, 2013, 08:45:13 AM »
i have done making $50 robot and i have programmed it also but it is going forward only and that to when i connect programmer with it using computer other wise it is not starting,please help me.... :
THANKS...
Offline jkerns
  • Helpful? 12
Re: problem with $50 robot
« Reply #1 on: August 06, 2013, 09:00:27 AM »
It runs when you have a programmer connected to your computer via USB, but not when it is disconnected - correct?
It could be that with the programmer connected you are getting power to the microcontroller from the USB, but when you disconnect power from your battery / voltage regulator is not getting to the microcontroller.
