Author Topic: need help..on operation in Uc  (Read 1922 times)
Offline henryTopic starter
« on: August 06, 2007, 12:30:20 AM »
guys..
I want to make logic operation in Uc....but I stuck..
this the algorithm..:
I have 2 register...R0 and R1....and then..I want to compare them...
if R0 is bigger than R1 then decrement R0
if R0 is lower than R1 then increase R0...
I want to write in assembly language...
this is my program:
MAIN:
MOV A, R0
CJNE A,R1,CHECK
MOV P0,0FFH
MOV P2,0FFH
CHECK:
In the label check..I don't know how we can find that R1 is bigger or lower than R0..
can somebody help...
thanks..
Offline rgcustodio
Re: need help..on operation in Uc
« Reply #1 on: August 07, 2007, 10:55:36 AM »
That'll depend on the MCU you are using. Not all assembly mnemonics are available in a specific MCU, some might rename the command you want.
If you're using an AVR try this site:
http://www.avr-asm-tutorial.net/avr_en/beginner/index.html
« Reply #2 on: August 11, 2007, 11:17:18 AM »
why assembly and not C?
« Reply #3 on: August 13, 2007, 04:12:36 PM »
Subtracting one from the other will yeild a positive or negative value (depending on ?C, might be reflected in a flag), if not zero of course.
In pseudo 'x86 code, it could be done something like this:
SUB  R0, R1
JZ   Do_Nothing
SUB  R0, R1
JNAE Increase_R0
DEC  R0
JMP DoNothing
Increase_R0:
INC  R0
Do_Nothing:
RET           ; or whatever
Last post October 13, 2009, 05:44:32 PM
by Webbot
Last post January 06, 2010, 05:36:13 PM
by SmAsH
Last post May 25, 2010, 10:46:00 PM
by celban
Last post July 03, 2010, 07:33:09 AM
