Author Topic: how to lift a weight of around 5 kg with a robot with accuracy and speed ?  (Read 1646 times)
Offline hkdhaneshaTopic starter
I WANT TO PILE UP BLOCKS OF .5 KG WITH TOTAL WEIGHT OF 5 KG.
I HAVE USED LEAD SCREW BUT ITS SLOW AND TAKES SOME TIME TO LIFT THE BLOCKS.
CAN I USE PNEUMATICS TO LIFT THE BLOCKS WITH HELP OF ARMS.
PLZ. GIVE SUGGESTIONS.
Yes, pneumatics can lift things, but they are very hard to get precise control with.
Direct acting gear motors would probably be best, with some kind of absolute encoder on the moving arm to know how far it's moving.
How far do you need to lift blocks?
Let's assume you can get away with a 30 cm arm. A .5 kg block would then exert 15 kgcm of torque, plus weight of arm, which is reasonable working load for an existing servo like the RX-64 or MX-64, and maybe even MX-28.
Another option would be a simple DC gearmotor with a high gear ratio (like Pololu 298:1 DC motors) and an encoder you build yourself, plus a motor driver and a microcontroller to close the loop.
