Author Topic: Help with first basic guide robot  (Read 1710 times)
Offline garagelaneTopic starter
« on: September 11, 2013, 03:57:28 PM »
I'm starting a new robotics project and could really do with some guidance from the knowledgeable folks of the society.
The scope:
Looking to build a guide or telepresence inspired robot but a bit more basic/stripped down
Some examples:
Initially I will be looking for the robot to be driveable initially by gamepad/remote, eventually moving to off-site control like a drone so to speak. So via secure internet/vpn connection to the bot. The last evolution will be to have an automated mode (sensor driven) as well but this will come later.
I would like to be able to voice communicate/have 2 way conversation through the robot with people but they won't have to see me.
Mountings include:
- 15-17inch LCD
- small form factor PC
- front, back and two side facing cameras at around 5" 6 to get a 360 degree views with out having to pan one camera (still open to reducing to 180 degree field of view)
- possibly a small thermal receipt printer
- amplified speakers
- microphone
- some sensors/or camera low at the base to pick up any low laying obstacles
- battery power to last at least 5 hours
- speed up to 2.5-3 mph
- I anticipate the maximum load/weight to be around 60kg/133lbs
The motion I believe works best as 2WD robot with 3rd wheel being a caster wheel.
For this project I'm hoping to keep the spend under $2k for all components
I'm looking for some guidance on motor/servo/gear/controlloer selection/recommendation for that weight and height to start.
Re: Help with first basic guide robot
« Reply #1 on: September 11, 2013, 07:00:07 PM »
Could probably reduce weight down to 30-40kg.
Wheel diameter around 200mm.  The Dongbu Tetra IV has  240mm diameter wheels but a 80kg payload capability.
Would a DC motor suffice for these requirements as notice a number of solutions with some higher payloads utilise AC servo motors?
« Last Edit: September 11, 2013, 07:05:21 PM by garagelane »
