Author Topic: Tracked rocker-bogie suspension, Rescue Robot  (Read 2820 times)
Offline bdeuellTopic starter
« on: September 18, 2013, 01:53:24 PM »
Hello,
I am new to this forum and I figured I would upload a video the latest robot I have been working on.
Rescue Robot - Going UP a curb
This project was constructed by the University at Buffalo Robotics Club. I am no longer directly involved in the project as I am now attending a different school for my graduate degree but the club is counting to design and construct the robot. Currently the robot only operates under remote control but autonomous control is in the design.
The robot features a tracked rocker boogie suspension designed with the intent of being able to passively navigate extremely rough terrain. This is the only robot I have seen with this design, so let me know if you have seen something similar somewhere else. The passive design was chosen as apposed to the active flipper design of most rescue robots so that it could easily operate under autonomous control ... and also because I like to try new things.  ;D So far results of the design have been promising but there are a few kinks to work out, mainly a adding a limit to the rotation of the track modules is needed.
Other features of this robot include:
- universal payload attachment
- hot swap-able battery with use of a UPS system
- rain proof, NEMA 3
- on board computer, mini ITX motherboard
More videos can be found at http://www.youtube.com/channel/UCpgICrCv1qymFex0rl2ghqw
Offline Roman505
Re: Tracked rocker-bogie suspension, Rescue Robot
« Reply #1 on: September 18, 2013, 04:36:49 PM »
Looking at this video http://m.youtube.com/watch?v=fab73SjLymw I think that rather than a simple limit stop you could add torsion bar springs to each axle, to allow fairly free conformation with ordinary terrain and increasing resistance to extreme rotation of the track axle. Not having tested it, my conjecture is that you would go for a spring rate that covers most situations but still ultimately relies on a limit stop rather than spring tension to prevent flipping in extreme cases; i. e. relatively soft, something to add useful tension. Currently, in that and other videos, the lack of tension seems to be reducing efficiency as well as introducing the flipping risk.
Offline Kylepowers
« Reply #2 on: September 22, 2013, 10:21:45 PM »
I agree with Roman505 on the torsion bar springs idea. Also as for this design I have seen similar ones to this used a few years ago in a FIRST Robotics Championship. In 2010 the game Breakaway. I was a mentor for a team in MN and I saw a team on the practice field who used a very similar design to this. It is a good design and you should continue to develop it. If I can ever find the team that made it I will try and link it.
EDIT:
Found one that is similar not the one I was thinking of but if you look at the drive train design you can see its built on similar principals.
https://www.youtube.com/watch?v=XECmOwmYiu8
« Last Edit: September 22, 2013, 10:26:40 PM by Kylepowers »
« Reply #3 on: September 23, 2013, 01:36:50 PM »
The Mars rover "rocker boogie" design has a cross bar that transfers torque between the left and right side boogies. I don't see such a bar in this design. Is this four indepdenent boogies?
Also, how tight turns can it make without the tracks coming off?
« Reply #4 on: September 23, 2013, 03:57:03 PM »
Thanks for the suggested solutions to the track flipping issue.
I like this idea, I think it would be ideal to keep the spring rate fairly low for positions in the range of +/- 30 degrees so there is little effect on level-ish ground but increase the spring rate for larger angles hopefully keeping the tracks down (pressed against the surface) on steep inclines such as the stairs instead of just preventing them from flipping over. Perhaps this could be achieved with a combination of multiple springs or through a progressively wound spring (not sure of a way to do this with torsion springs tho).
The NASA Mars rover uses a differential transmission between the left and right sides of the suspension so that when one side rotates in one direction the other side will rotate in the opposite direction. This robot uses a linkage bar that pivots on the back of the robot connected on each side by ball linkages to achieve a similar motion.
Check out this video to see how this linkage works: Rescue Robot - Tethered Test 1
Yes, each of the four track module pivots freely on the suspension. A single track module can be compared to a boogie assembly on a wheeled rocker bogie suspension, the front of the track can be viewed as one wheel and the back as a second wheel with the frame of the track module being the boogie link in the suspension. This makes he entire system comparable to an eight wheeled rocker boggie suspension.
This was one of my concerns with the design but we were able to turn the robot in place without the causing too much of a problem. The tracks did start come off their alignment pins a little after a full rotation but driving forward for a couple of feet got them back in place. During these tests the tracks were not fully tensioned either so correcting that should also improve the performance.
« Reply #5 on: September 23, 2013, 07:30:57 PM »
Thanks for the details! I didn't see that the black bars worked as link arms in the original video, so the second video helped.
