Author Topic: Non-inverting op-amp question  (Read 3554 times)
Offline hazzer123Topic starter
« on: August 08, 2007, 01:57:09 AM »
I need to amplify a signal that varies around the range 2.4-2.6 volts, so that it outputs 0 - 5V.
I understand the basic circuit where the gain is 1+ (R2/R1), but i want an offset, where 2.4V into the V+ pin creates 0V on the output pin (and vice versa with 2.6V in = 5V out).
Any one have any ideas?
My op-amp has no balance pins.
« Last Edit: August 08, 2007, 02:16:53 AM by hazzer123 »
www.icrobotics.co.uk
Re: Non-inverting op-amp question
« Reply #1 on: August 08, 2007, 06:05:56 PM »
So, you need a gain of ((5-0)/(2.6-2.4)) = 25, with an offset of -2.4V.
The offset will also see the amplication factor, so you need to add an offset of only -2.4/25 = -96 mV.
Since it's a negative numbe, easiest way is to lift your inverting input by 96 mV (since inverting a minus yeilds positive).
« Reply #2 on: August 09, 2007, 07:30:40 PM »
Another method Ive used is to have two seperate grounds.
Set the amplifier circuit ground to 0V, and set your microcontroller ground to 2.4V.
To do that, you would use a 2.4V regulator for microcontroller ground, and a 5V+2.4V regulator for the positive voltage of your microcontroller.
Then just design your amplifier gain to not go above the 5V+2.4V voltage.
Ok maybe not elegant, but it works really well!
