Author Topic: Best motor selection for my Robot  (Read 1077 times)
Offline rwkempTopic starter
« on: October 07, 2013, 09:52:31 AM »
Hello
I´m student of Electrical Engineering, and I am new here
I need develop one sumo bot with the maximum size 40 x 40 x 40 (cm)
the maximum weight is 9 Kg
What is the best motor for thos application ?
How I can calculate it ?
Re: Best motor selection for my Robot
« Reply #1 on: October 07, 2013, 11:12:25 AM »
Check out the motor calculator found by clicking on "Robot Tutorials" in the upper right corner of this web page.
« Reply #2 on: October 07, 2013, 09:55:17 PM »
The best motor(s) is(are) the one(two) that:
- leave(s) you enough weight budget for the rest of the chassis, batteries, and electronics
- has the appropriate gearing for your application
- has the strongest torque given the input voltage you supply
- has the best durability record
- you can afford
You need to look around for various options from various vendors, and do some calculations on the other weights involved, as well as desired wheels and traction options, before you can narrow down to a particular motor.
