Author Topic: Using an old six wire servo?  (Read 2898 times)
Offline GertlexTopic starter
  • Helpful? 23
« on: August 08, 2007, 02:40:38 PM »
I've got this old old servo that came with the car that I converted to bluetooth.  It's totally free of any manufacturer's name, just the blue CE sticker (electronics/electrics standards compliance or something)
Is it possible to use such a servo with a servo controller (Mini SSC II) that uses three wire servos?
Orange and black: the motor terminals
Blue soldered to the entwined terminals of the capacitors that also link the two motor terminals
Green, White, Yellow: three terminals of the potentiometer, I think.  White is the center terminal wire... three wires means its being used to monitor the voltage, I think.  Yes, I severed all six wires from the original circuit board.
Quoting a website of a guy that has refurbished a few of these NIKKO Alienators:
The included servo was in an odd L shape and had 6 wires for what seemed to be a manual position sensor. Really low tech.
Does this pretty much mean the servo is useless until, perhaps, when i start dealing with real control boards?
I can post pictures if needed.
I
Re: Using an old six wire servo?
« Reply #1 on: August 08, 2007, 05:10:50 PM »
What you have is just two parts of a servo, the motor and the (position) feedback potentiometer. You miss the electronics tying it together.
The blue lead should go to Protective ground/the metal frame of a vehicle.
The potentiometer will go between ground (or a low ref. voltage) and +V (or a higher ref. voltage than the other end). The wiper (the center terminal) will thus give a voltage which is proportional to servo position.
Nope, it could be used with an op-amp to give positioning based on an input voltage.
Make them of Claudia Schiffer then ;)
« Reply #2 on: August 11, 2007, 09:24:54 AM »
You can also send the voltage from the pot into the ADC of your microcontroller. Then you can program your own servo into some form of feedback system.
I can pretty much picture in my head what it looks like, but Im curious to see how the pot is hooked up to the motor . . .
or Roseanne!
(just kidding)
