2
Author Topic: accuracy  (Read 793 times)
Offline Ana_DigTopic starter
accuracy
« on: December 08, 2013, 08:21:04 PM »
Hi friends, I search after examples or videos or names of robots or machines that work in a very accurate scale something like one millimeter of accuracy or better accuracy, so if you know about a robot or machine that work very accuracy so I will glad if you can write this in this thread.
Offline hobbes
Re: accuracy
« Reply #1 on: December 08, 2013, 08:31:14 PM »
ultrasonic motors are used in camera autofocus for very precise and fast movements.
  • Helpful? 99
Re: accuracy
« Reply #2 on: December 09, 2013, 08:06:41 AM »
And piezo actuators work within the nanometer range:
http://www.piezo-usa.com/piezo_actuators_nanopositioning/
Offline bdeuell
  • Helpful? 14
Re: accuracy
« Reply #3 on: December 09, 2013, 11:44:05 AM »
Most CNC machines and many other machines used in manufacturing can operate well within 1mm of accuracy.
On a side note 1mm is not considered very accurate in many fields. As can be seen from the other posts there are many applications that require much higher tolerances.
  • Helpful? 99
Re: accuracy
« Reply #4 on: December 09, 2013, 11:51:13 AM »
Actually: Most CNC machines and many other machines used in manufacturing can operate well within 1/1000 of an inch which in 0.039mm or 39um and many can run much better than that.
Offline johnwarfin
Re: accuracy
« Reply #5 on: December 10, 2013, 11:18:26 PM »
or microscope probers in medical research and semiconductor mfg where sub-micron accuracy is common.
