Author Topic: Tracking moving object  (Read 1512 times)
Offline tecgatyTopic starter
« on: August 11, 2007, 09:49:35 AM »
I am newbie for Robotics. But I have been Interested for a long time. Now I am planning to participate in a competition.
Here's my task >>>>
I should make an autonomous robot. Its starting position is in a RING (A circular Path. Lets call it MY RING). It will have to detect if the target is enters the danger region  (A small circle around MY RING) . The target is also a robot but only its manual. The target starts from a fixed point and tries to enter danger region.
Now my robot has to track the opponents robot and signal (LED/SOUND) if it enters the danger region and should stay within the ring it started.  It should not get into contact with the manual (or Enemy) robot. The ring has a red line on the black background.
I am planning to use a color sensor ( Is it fine??) to stay within the ring.  What sensor should i use to detect the position of the target?
NOTE : I need not care the linear movement of the enemy unless it is into the danger region. Till then I have to keep track with the Horizontal movement of the target..
Re: Tracking moving object
« Reply #1 on: August 11, 2007, 09:56:00 AM »
Put a scanner on it ;D
http://www.societyofrobots.com/robot_sumo.shtml
The scanner will also give you range, too.
« Reply #2 on: August 11, 2007, 07:20:26 PM »
HHmmm, that really makes it.
But my problem is that my robot has to detect the enemy robot while its on move... I mean I want something like target locking. I will identify the robot with any of the sensors.. But I have to keep a track of it from then.. And I need to move along with it and should ensure that I am in my supposed track..
The attached  shows where I have to be in.. Now the Enemy robot can enter through any of the openings of outer barrier. I am desperate about this. please help me out.
The other pic shows the starting position of enemy robot (The orange semi-circle). I think I can make advantage of this, as I all ready know the initial distance and direction of the enemy...
Thank You.
Last post April 27, 2008, 01:51:34 PM
Last post June 16, 2011, 09:12:55 PM
by kibbles201
Last post November 11, 2012, 09:13:10 AM
Last post December 16, 2012, 08:33:07 AM
by forrestschofield
