Author Topic: Stepper motor and driver  (Read 752 times)
Offline drinuTopic starter
« on: February 11, 2014, 10:46:47 AM »
Hi all,
If I use a Unipolar stepper motor in a Bipolar configuration, will I loose torque or speed?
I was considering to buy the 23HS32-4008S (link below).
http://www.stepperonline.com/nema-23-cnc-stepper-motor-20nm283ozin-4a-23hs324008s-p-70.html
Will this motor work fine with the DM556 driver? Also, will I be able to get a decent speed with a 32V switch mode power supply?
All kind of help/suggestions will be appreciated.
Thanks in advance.
Re: Stepper motor and driver
« Reply #1 on: February 11, 2014, 08:22:32 PM »
A unipolar stepper (5 wires) cannot be used in bipolar mode. However, the stepper you linked is a bipolar stepper that can be wired as unipolar.
The stepper is rated for 4.0A per phase, so if your power supply can deliver at least 8A, and you use a proper chopping driver, then you should get the best possible rated performance out of that stepper motor.
