Author Topic: Rotary Encoder  (Read 1085 times)
Offline drinuTopic starter
Rotary Encoder
« on: March 17, 2014, 03:23:28 PM »
I am interested in buying the rotary encoder in the link below. The specs states  that it can be supplied with 5V to 24V. Does that mean that I can operate the encoder with 5V or is that referring to the signal (collector) pin voltage range?
Also, does rotary encoders of this type create debouncing?
Thanks in advance.
http://www.ebay.co.uk/itm/100P-R-Incremental-Rotary-Encoder-6mm-Shaft-AB-Phase-for-Measuring-Acceleration-/281232555037?pt=UK_BOI_Industrial_Automation_Control_ET&hash=item417ac43c1d
« Last Edit: March 17, 2014, 03:25:26 PM by drinu »
Offline Kohanbash
Re: Rotary Encoder
« Reply #1 on: March 17, 2014, 05:10:17 PM »
Hi
You should be able to power it from a 5-24V source on the VCC pin.
You should not need to debounce an encoder, you can plug it directly into your motor controller (or encoder input interface).
I think the note about not connecting VCC to an AB channel is just a warning not to short an input pin to VCC or you can damage the sensor.
Re: Rotary Encoder
« Reply #2 on: March 18, 2014, 12:36:33 AM »
Thanks for the reply. Is a 1kohms pull up resistor enough to connect with pin a and b?
Offline Kohanbash
Re: Rotary Encoder
« Reply #3 on: March 18, 2014, 07:54:40 AM »
You can normally just connect the A and B channels to your motor-controller/encoder-interface with no pull up resistors.
