Author Topic: Charger for a 6V 2000mAh NiMH Battery, with the Hitec Connector  (Read 958 times)
Offline CeresVoyagerTopic starter
Hi anyone that reads this,
i am a total newbie at this and have recently decided to get involved in robotics, as i have always wanted to. Anyway, I am ordering the parts for the $50 robot but I am not able to find a charger that has the right connector for this battery: http://www.tenergy.com/11112
Can somebody help me and offer a solution? I was thinking of getting a normal charger with a tamiya connector and getting an adapter for the connection of to the hitec connector on the battery. However, if someone can offer a better solution that hopefully requires no adapter, that would be amazing!
Thanks,
CeresVoyager
Re: Charger for a 6V 2000mAh NiMH Battery, with the Hitec Connector
« Reply #1 on: April 03, 2014, 09:11:27 AM »
It is not uncommon to need to make adapters from one type of connector to another.
A reasonable priced charger that works well is the IMAX B6. This does come with adapters to most of the popular hobby battery connectors.
http://www.skyrc.com/index.php?route=product/product&product_id=9
This charger will work fine for that battery. Just be sure to use the battery specs to setup the charging (1C max charge rate).
