Author Topic: [advertisement] New Stepper Motor Mounts  (Read 2583 times)
Offline ServoCityTopic starter
  • Helpful? 18
« on: April 04, 2014, 09:18:06 AM »
These new stepper motor mounts allow you to integrate stepper motors into your robotic project that requires precise position control.  By incorporating the .770” and the 1.50” hub pattern, it is easy to connect nearly any Actobotics™ component including channel.  Mounts are machined from 6061-T6 aluminum for superior strength and durability. Start building your 3D printer or precision camera slide now!  Each mount will come with the fasteners required to attach your stepper motor. Sizes available – NEMA 14, NEMA 17 (NEMA 8, NEMA 11, and NEMA 23 coming soon!)
http://www.servocity.com/html/stepper_motor_mounts.html#.Uz7JevldV7s
Offline venturemfg
Re: [advertisement] New Stepper Motor Mounts
« Reply #1 on: April 08, 2014, 01:19:07 AM »
The configuration sounds good. This might will able to handle a heavy loads. Can you please share  about how stepper motor is integrated?
Offline benedictzhang2018032
New Stepper Motor
« Reply #2 on: April 19, 2018, 08:13:53 PM »
Stepper Motors provide precise position and speed control, without the need for feedback devices to sense position. The operation of step motors is controlled through electrical pulses that the drive converts to current flowing through the windings of the motor. As the current is switched the motor rotates in precise steps of a fixed angle. The motor and drive constitutes a low cost control system that is precise and simple to construct.
https://www.moonsindustries.com/c/stepper-motors-a02
Offline Peterlovediy
« Reply #3 on: December 11, 2019, 02:10:41 AM »
The new designed NEMA 17 Stepper Motor Alloy Steel Mounting Bracket can match standard Nema 17 stepper motor, and also include the mounting holes for Nema 17 Economy Planetary Geared Stepper Motor.
https://www.omc-stepperonline.com/nema-17-bracket-for-stepper-motor-and-geared-stepper-motor-alloy-steel-bracket-st-m1.html
