Author Topic: motor connections with L298  (Read 7110 times)
Offline darkjungleTopic starter
« on: August 15, 2007, 10:29:51 AM »
how to programme to slow down the speed of motoer using a l293 motor ic.what programme to be written?
Offline Steve Joblin
Re: motor connections with L298
« Reply #1 on: August 15, 2007, 12:16:00 PM »
The L293 can only control direction... to control speed you need to "pulse" the signal off and on very quicly... The technique is called Pulse Width Modulation, or PWM for short.  Many microcontrollers have a PWM command that will make it very easy to do.
For examples of how you do it with a Parallax Basic Stamp, check out this link (the code is at the bottom of the page)... http://www.me.umn.edu/courses/me2011/robot/technotes/L293/L293.html
Offline elixier
  • http://www.techiesworld.org
« Reply #2 on: August 15, 2007, 12:28:51 PM »
The only thing you have to do is to generate A Pulse Width Modulated Signal with the help of the Program and feed it to the Control input of the L293 for the Clockwise or the Anticlockwise direction.
The PWM Signal generated by the Microcontroller can help in slowing or controlling the speed of the Motor.
look for following links.
http://www.societyofrobots.com/schematics_h-bridgedes.shtml
http://www.societyofrobots.com/member_tutorials/node/33
  Techies Rules The World
« Reply #3 on: August 17, 2007, 05:39:05 AM »
How should be the motor driver like l298 be connected to armega 8.Where should the 4 input pins be connected to atmega 8.
Offline black-code
« Reply #4 on: August 19, 2007, 06:07:14 PM »
U can use l298, with it u can control both the speed and the direction and it's good too when interfacing motors with microcontrollers.
the speed can be controlled by PWM (pulse width modulation).
Black-Code
« Last Edit: August 19, 2007, 06:09:52 PM by black-code »
« Reply #5 on: August 21, 2007, 03:11:23 PM »
The ATmega8 has a multitude of digital output pins. On my $50 robot you will notice the servos connected to some pins. You can connect the l298 in the same way.
For example use pins PD0, PD1, PD2, and PD3.
$50 robot schematic for reference
http://www.societyofrobots.com/images/sbs_avr_schematic.png
Offline Hal9000
Last post September 25, 2007, 09:15:32 AM
by snow
Last post January 31, 2008, 01:02:10 AM
by TrickyNekro
Last post January 17, 2009, 07:14:27 PM
by Webbot
Last post October 21, 2012, 06:00:05 AM
by Batienzaxcore
