Author Topic: need servo and vbasic stamp help ?  (Read 2495 times)
Offline ltmhallTopic starter
« on: October 06, 2006, 10:08:11 AM »
I’m Building an autonomous mobile robot using differential drive and have a few questions. I’m using two Hitec 422 servo motors, a Basic Stamp II (education board), two Dubro 2.75 in. wheels, and a NARP 4cm omni direction wheel.
1)   If I’m using two HS 422 servo motors and a Basic Stamp II do I need an H-bridge. I was planning on connecting my servo motors to an L293 chip then connecting the L293 to a Basic Stamp, but a classmate told me I didn’t need one, I could connect the servos straight to the Basic Stamp. Please Help!
2)   If I need to connect my servos to an H-bridge do I actually open my modified servos and connect the two pins of the motor to the H-bridge.
3)   I read a regular caster is a very great ideal for the third wheel, does anyone know a good way to mount an omni directional wheel to an aluminum chassis.
Re: need servo and vbasic stamp help ?
« Reply #1 on: October 06, 2006, 11:46:33 AM »
Servos have their own built in circuitry, which is why I highly recommend them. Your classmate is right, no H-bridge required. Just give the servo between 4 and 6 volts power, and a square wave signal to the signal line (which is where you connect the stamp to), and thats it!
For the omniwheel castor, there are many ways to attach it. One would be get a long rod, put the omniwheel in the center, then bend the rod into a U shape. Then attach the two ends of the U to the robot chassis.
Last post July 01, 2007, 02:27:42 PM
by Steve Joblin
Last post July 17, 2007, 09:22:02 PM
by Robotboy86
Last post August 18, 2007, 10:38:56 AM
Last post August 27, 2007, 03:46:42 PM
by hazzer123
