Author Topic: Check this quadcopter build, I need advice as im a newbie  (Read 849 times)
Offline TheAnonyMooseTopic starter
« on: May 19, 2014, 10:53:06 PM »
This is the current build I have, nuts and bolts excluded as I can figure that out later. If you can suggest better parts/deals please do.
This will all be running via a rasberry pi B model.
1 x GPS antenna = $13.5: http://www.cooking-hacks.com/internal-gps-antenna
1 x GPS shield = $139: http://www.cooking-hacks.com/gps-shield-for-raspberry-pi
Possiblities:
4 x 1090kv motor = $60: http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=18151&aff=588847
4 x 920kv motor = $100: http://www.quadrocopter.com/DJI-Phantom-Replacement-Motor_p_919.html
2 x 14 inch propeller pair = $20: http://www.quadrocopter.com/14x55-Multi-Rotor-Propeller-Pair_p_972.html
2 x 8 inch propeller pair = $15: http://www.quadrocopter.com/APC-10x47-SlowFly-Propeller-Pair_p_374.html
Now for my main questions:
1) Would any of the above be able to get me around 15-20+ m/s ascent?
2) I want to maximize battery life (I havent included one) I want to be able to run the above for around 3 hours+ with a fast recharge rate, can you suggest a battery capable of that?
3) What is the best camera for high quality, wide angle photographs/video for less than $300 (and that can interface with rasberry pi)
Feel free to answer any or all of my questions, and suggest anything you want.
EDIT:
I failed to mention I have access to a 3d printer and printing is around $0.05-$0.10 per cubic centimeter of material, I plan on using it to make a lightweight frame for my quadcopter
« Last Edit: May 19, 2014, 10:59:14 PM by TheAnonyMoose »
Re: Check this quadcopter build, I need advice as im a newbie
« Reply #1 on: May 20, 2014, 02:32:25 PM »
First, 3 hour flight time for a quadcopter is probably not realistic. The weight of the battery drives up the need for power for motors which drives up the weight of the battery more, ...
Second, A 3D printed body may delaminate under force. For things like brackets, 3D printing can work fine, but for things like the main struts/arms, I wouldn't rely on that.
Third, why a GPS shield? A USB GPS stick or puck can be had for half of that price, as can a TTL-UART GPS. The shield may be slightly more plug-and-play, though.
Fourth, I'd suggest going to a quad copter forum to get a wider range of advice.
« Reply #2 on: May 21, 2014, 11:50:09 AM »
I fully agree with all of jwatt's comments.
Your expectations are completely off base including the idea of using an R-PI as the flight controller. You need to do a lot of web searches and lots and lots of reading. Then decrease your expectations to about a tenth.
