Author Topic: CW5045 Stepper driver  (Read 1802 times)
Offline drinuTopic starter
« on: June 14, 2014, 02:32:10 PM »
Hi all,
I bough the CW5045 stepper motor driver.
I will be connecting the STEP, DIR and ENA to a PIC microcontroller. Do I need to include a current limiting resistor with every input or should I connect them directly to the PIC output?
If a resistor is requires, what value would be suitable?
Thanks in advance.
Offline jkerns
  • Helpful? 12
Re: CW5045 Stepper driver
« Reply #1 on: June 14, 2014, 03:42:40 PM »
On the 4th page of the data sheet you referenced, it shows that inside the driver, each of these inputs has a current limiting resistor and an LED (for optical isolation), with the current required being < 20 ma. If the data sheet is accurate, that would suggest that additional current limiting resistors would not be necessary or desired.
