Author Topic: Problems running motors with sabertooth  (Read 1033 times)
Offline macelizTopic starter
« on: July 26, 2014, 09:19:58 PM »
I'm running two 24V 35amp motors with a Sabertooth Dual 25A 6V-24V Regenerative Motor Driver connected to a remote controller and it is working fine but after some minutes the motors stop, my assumption is the wiring is getting to hot as I can feel it and are not allowing the current to flow but I'm not sure.
If I wait some seconds the motors work fine again.
I'm using 12 gauges wires and planning to change it for 8 gauge wires?
Do you think I'm doing the right assumption or might be something different?
Offline Tommy
Re: Problems running motors with sabertooth
« Reply #1 on: July 27, 2014, 03:12:36 AM »
maceliz, something seems wrong with the above line(using 25A drive with 35A motor?)
do you have a model or part number for the motors your using?
Tommy
Offline jkerns
  • Helpful? 12
« Reply #2 on: July 27, 2014, 07:27:39 AM »
If you are running 35 amp motors through a 25 amp drive, it is likely that the driver is overheating and shutting down.
Too small wires will have a voltage drop across them and waste power and in the worst case melt the insulation, but they would not typically cause the symptoms you describe.
« Reply #3 on: July 27, 2014, 03:05:37 PM »
jkerns is right, the motordriver is going into 'thermal shutdown'.
Ideally, you should use a motordriver of 35 amps.
Another option is to run your motors at a smaller voltage, or PWM to no more than perhaps 70% duty. While the driver might not overheat anymore, the motors would have very reduced torque/rpm.
