Author Topic: RTC on axon  (Read 1551 times)
Offline the_edge123Topic starter
RTC on axon
« on: July 27, 2014, 04:11:33 AM »
I'm interested in getting the axon2.
I would like to know if the RTC is enabled to timestamp sensor data.
Fabien
Re: RTC on axon
« Reply #1 on: July 27, 2014, 02:17:58 PM »
There is no real time clock on the Axon, if that's what you mean.
You can however use the on-board timer to time-stamp your data, but it will drift slowly over time (a few minutes per day). For most projects that isn't a problem.
Otherwise, you can buy a separate RTC to use with your Axon, or measure the error and then time shift your data.
