Author Topic: Programming with limited RAM  (Read 1765 times)
Offline mstachoTopic starter
  • Helpful? 10
« on: August 25, 2014, 08:13:11 AM »
As my adventure with the TI MSP430g2553 continues, I'm struck by something: there are only 512 bytes of RAM, compared to the Arduino and Axon II which has some 8KB (at least for the Mega).  Strangely, it has 16KB of flash.  So I was wondering something: are there tricks to writing large programs (ie: ones that could never fit into RAM but can easily fit in flash) that are used?
I can imagine something like this: write the entire program in flash (including how it WOULD look in RAM once loaded), then write some kind of operating controller that selectively loads/unloads the RAM with the flash data as it is needed.  As long as you are doing everything sequentially and interrupts aren't killing you, that should work...right?
I know that we can optimize the code to use LESS RAM, but I'm talking about a case where there is just so much code that even after optimization you still have no hope of loading it all.
Mike
Re: Programming with limited RAM
« Reply #1 on: August 25, 2014, 11:20:13 AM »
Are you sure the code needs to be in RAM to run?? Most of these small processors execute code from FLASH, RAM is only used for variables and data buffers.
  • Helpful? 10
« Reply #2 on: August 25, 2014, 02:13:51 PM »
Huh, I guess, if that's the case, then that answers my question right away :-P  I suppose the question would still remain for very large arrays, but those are (relatively) easy to store in flash anyway.  Neat.
