Author Topic: Axon 2 stuck bootloading  (Read 1791 times)
Offline jrm06cTopic starter
« on: September 23, 2014, 03:33:11 PM »
I've been programming the axon 2 without any problems. Now it suddenly (after programming it with a code revision, as usual) will not run through the initialization process and the LED does not display anything. The axon will program each time I attempt to program it but afterward the controller never seems to go into normal running mode. I've tried power failing the board but that does not change the behavior. Any ideas on how to fix this issue or what caused it?
  • Helpful? 111
Re: Axon 2 stuck bootloading
« Reply #1 on: October 07, 2014, 12:18:59 PM »
Do you have a hardware programmer - eg AVRISP MKII or similar?
How big is your program? Perhaps a screen dump from the end of the compile.
