Author Topic: C compiler recommendation? (not microcontroller)  (Read 10277 times)
Offline AdminTopic starter
« on: August 19, 2007, 09:22:05 AM »
I need to do some robot navigation testing that would cause too much trouble to do on a microcontroller.
I basically want to run the code on my laptop and fiddle with the output until I like it. Then I can port it over to a microcontroller.
So the question is, does anyone have any recommendations for a C compiler? I used to have a good one but I cant remember what it was. I think Borland Turbo C?
Any recommendations?
Offline cybcode
Re: C compiler recommendation? (not microcontroller)
« Reply #1 on: August 19, 2007, 09:50:57 AM »
There are so many. Are you looking for one for Windows?
lcc-win32 is easy to set up and free, but can only compile pure C as far as I know, not C++ (http://www.cs.virginia.edu/~lcc-win32/).
Open Watcom is also quite easy to set up and free (http://www.openwatcom.org/).
There is of course also MS Visual C++ Express (http://msdn2.microsoft.com/en-us/express/default.aspx).
MingW is a UNIX style development system (for Windows) with GCC and other related tools (http://www.mingw.org/).
Cygwin is another such system (http://www.cygwin.com/).
There's also Turbo C++ but I haven't used it (http://www.turboexplorer.com/cpp).
Offline snow
« Reply #2 on: August 20, 2007, 08:20:34 AM »
I like Dev-C++ (http://www.bloodshed.net/devcpp.html). It's an IDE that comes with Mingw (gcc) compiler.
(F9 to compile & run  ;))
« Reply #3 on: August 20, 2007, 08:28:00 AM »
You guys posted a lot of C++ compilers . . . can these also do C?
The program Im writing is just for code verification for another program Im writing for a microcontroller, so I want it to be in C.
Offline cybcode
« Reply #4 on: August 20, 2007, 09:09:39 AM »
Generally, every C program will compile with a C++ compiler. It doesn't work the other way around. C++ is C with some extensions. If you plan to move your code back to a pure C compiler eventually (e.g. for the microcontroller), you should make sure you don't use any C++ extensions while developing with the C++ compiler.
Offline JesseWelling
  • Only You Can Build A Robot!
« Reply #5 on: August 20, 2007, 10:35:27 AM »
I like gcc.... ;D
Offline DomoArigato
« Reply #6 on: August 21, 2007, 10:09:49 AM »
I've set up eclipse + mingw(GCC) without much hassle.  It works well for me.
Offline Robotboy86
« Reply #7 on: August 25, 2007, 05:51:30 PM »
gcc for the win! :)
Last post February 26, 2010, 12:26:13 PM
by z.s.tar.gz
Last post January 21, 2011, 01:25:02 PM
Last post February 28, 2012, 10:12:45 PM
by alucard
Last post April 14, 2012, 10:07:57 AM
by joe61
