Author Topic: last step in modifying the servo tutorial  (Read 1433 times)
Offline ZevooTopic starter
« on: November 27, 2014, 01:45:39 PM »
http://www.societyofrobots.com/actuators_modifyservo.shtml
In the last step it says to send the PWM to the servo. How do I do it?
Offline jkerns
  • Helpful? 12
Re: last step in modifying the servo tutorial
« Reply #1 on: November 27, 2014, 07:14:54 PM »
At that point you are done. This is not an extra step in modifying the servo.
Sending a pulse modulated signal to the servo is how you tell it what to do - your microcontroller will send the pulse signal to get the servo to turn at the desired speed
« Reply #2 on: November 28, 2014, 01:32:28 AM »
oh okay :) then I have done everything correctly :)
