Author Topic: Need help for Voice recognition car  (Read 5310 times)
Offline mklrobo
  • Helpful? 14
Re: Need help for Voice recognition car
« Reply #30 on: April 13, 2015, 01:24:05 PM »
 ;D Hello!
I am trying to put together a system, but have a BIG problem with programming the
Axon, at this time. If I can not program the MCU, I have to  use another MCU to
get the projects done, and that would be terrible. :'( You can see my progress,
so far, in the miscellanous section, Analyzing the Axon: Coding, Construction, and Contraptions.
 8) 8)
Offline mklrobo
  • Helpful? 14
« Reply #31 on: May 01, 2015, 09:45:00 AM »
 ;D Hello!
Still working on the program. Have located more info on the speech control. Just have to
be able to download a program to the Axon.  :-\
Offline APJ1234Topic starter
« Reply #32 on: May 02, 2015, 07:22:03 PM »
Okay so you are very close to the goal.
Offline mklrobo
  • Helpful? 14
« Reply #33 on: May 03, 2015, 03:21:56 PM »
I will try going the cheapest route first. A single board voice control by Ardunio may do the trick.
This will suffice for simple control of motors, as you have indicated. I think Wow-wee toys sell
a toy called Robosapien that may have voice control already. (I would rather program one.  ;D )
For the more advanced voice commands, will be quite a programming job. You will have to buy
the software I am using, if you go that direction. I will cover the basic programming first in the Axon,
for testing and base coding purposes.(So you know your Axon is working, or if you blew a port:'( )
This builds the basic code "toolbox" to build upon. You will always need to check out other ports
and features. The Axon you are using is not only good for a hobby, but you may find, a tool that you
can not do without.(Like the Sonic Screwdriver on Dr. Who;D ;D ;D )
« Reply #34 on: June 22, 2015, 06:43:48 PM »
Hey man I just needed to know any other progress in the project.
Offline mklrobo
  • Helpful? 14
« Reply #35 on: June 23, 2015, 05:30:38 AM »
 ;) Hello!
I am working on the making of the hex file, just to get the Axon programmed.  ??? Once I get that
straightened out, I can proceed to work on the voice control. The only other way around using the
Axon, is to use a beaglebone or Raspberry Pi to process the voice, the follow through with the appropriate
command. I would have to find a dragon dictate or similar program to do this. I am hung at the Hex file at the moment.   :'(
« Reply #36 on: September 23, 2015, 10:35:18 AM »
Hi
I am sorry I didn't check on you for this long but I was working on this by my own and it didn't turn out well.
I just need to know did the voice control is working or is it still in progress?
Offline mklrobo
  • Helpful? 14
« Reply #37 on: September 23, 2015, 02:39:11 PM »
 :'( no new updates, at this time. I am trying to program the Axon with AVR studio 6, and learning to
use the new Raspberry PI II. There MUST be an answer, somewhere!  :'(
