Author Topic: Atmega 16  (Read 1803 times)
Offline darkjungleTopic starter
Atmega 16
« on: August 22, 2007, 07:03:37 AM »
What would be the circuit connections in a line following robot,if i want to use atmega 16 instead of 8.
Should the pins xtal1 and xtal 2 be used or not.
Re: Atmega 16
« Reply #1 on: September 04, 2007, 09:23:25 AM »
Hmmmm just check the datasheet pinout of the ATmega16.
The pin numbers and locations will be different, but the pin names will be the same.
For example, match AREF to AREF, B3 to B3, etc.
You will need to make slight modifications in code, as described for the ATmega168:
http://www.societyofrobots.com/step_by_step_atmega168_swapout.shtml
Only if you want to add a crystal to boost processing speed. Unless your bot does complex algorithms, I wouldnt bother with it.
Last post January 03, 2007, 01:40:30 PM
by Hal9000
Last post February 09, 2007, 06:43:27 PM
by JonHylands
Last post June 09, 2007, 04:32:32 PM
by 555 timer chip guy
Last post May 18, 2008, 07:54:42 AM
