Author Topic: Bi-polar stepping motors?  (Read 2240 times)
Offline BANETopic starter
  • E=roboticsC^2
« on: August 25, 2007, 08:12:30 PM »
Does anybody know anything about bi-polar stepping motors and if they are more powerful and accurate than servos?
Most importantly, how to control them?????
« Last Edit: September 01, 2007, 11:34:11 AM by BANE »
Offline hazzer123
Re: Bi-stepping motors?
« Reply #1 on: August 26, 2007, 06:05:01 AM »
Im assuming you mean bi-polar stepping motor.
There are advantages and disadvantages to both.
A servo has absolute positioning system, whereas a unmodified stepper motor has only relative position (if you count the number of steps).
A stepper motor has continuous rotation, and unmodified servo has a limited range.
A servo has its drive electronics onboard, you standard stepper motor doesnt.
A servo has a larger torque/size than a stepper.
To control them check google -
here are a couple of links
http://www.piclist.com/techref/piclist/jal/DrivingBipolarStepperMotors.htm
http://www.ams2000.com/pdf/step101.pdf
PS - Unipolar steppers are much easier to drive.
www.icrobotics.co.uk
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
« Reply #2 on: August 26, 2007, 11:32:52 AM »
I disagree. Using a L297 and a L298N you can easily drive a bipolar stepper. You need one pin for direction (clockwise/counterclockwise), a pin for steps and optionally a pin for full_step/half_stepping from your micro to the L297.
Also bipolar steppers have a better power/weight ratio (more powerfull for the same weight).
Offline hazzer123
« Reply #3 on: August 26, 2007, 05:59:15 PM »
hmmm it looks like you are correct :)
Ive only ever controlled stepper motors with transistors, not using any fancy driving chips, but it seems a lot neater to use one.
  • E=roboticsC^2
Re: Bi-polar stepping motors?
« Reply #4 on: August 26, 2007, 07:23:28 PM »
I've got a question, could you show me a diagram of the transistors you used?  I didn't know that you could do that.
« Last Edit: August 31, 2007, 06:07:22 PM by BANE »
Offline hazzer123
« Reply #5 on: August 27, 2007, 05:49:44 AM »
Have a look at the right hand side of this schematic -
http://aaroncake.net/circuits/stepper.asp
Last post January 22, 2006, 02:33:50 AM
by monsta
Last post January 20, 2008, 04:38:43 PM
by Steel_monkey
Last post January 17, 2008, 04:32:36 PM
by benji
Last post February 23, 2008, 07:43:18 PM
by airman00
