Author Topic: Cmake configuration issue  (Read 1413 times)
Offline walid1544Topic starter
« on: November 21, 2016, 04:12:30 AM »
hello guys, can someone tell me what's wrong here please
Offline Gertlex
  • Helpful? 24
  • Nuclear Engineer Roboticist
Re: Cmake configuration issue
« Reply #1 on: November 24, 2016, 01:55:57 PM »
That's a really helpful error message... Probably install gfortran if you don't have that already, and then set the environment variable its telling you to set.
I could be completely wrong, of course! You didn't tell us anything about your setup.
I
« Reply #2 on: December 15, 2016, 11:40:22 AM »
so here im trying to build a combination of model predictive control algorithm, i do have the fortran installed on my code blocks as i'm using the latter to configure my make file, i'm a bit new to this field, is that all of the information you need ? i will attach the log file aswell hopefully it helps ,thnx a lot for ur concern sir, have a good one.
