Author Topic: making a coupling for transmission of motion from motor to a shaft  (Read 1337 times)
Offline couplingTopic starter
We buy motors from a second hand market. Almost all of the motor's rotors are cylindrical. When i went to manufacture a coupling for transmission of motion from this motor to a shaft. The worker said to transfer power successfully you need a  D cut. Other wise slipping will occur. I don't understand then why are the rotors cylindrical in the first place is they cant efficiently transfer motion.
Second option is to do a fix it with a bolt by making a through home, through both coupling and shaft.
Can someone shed some light on this topic.
Thanks.
Offline rastas
Re: making a coupling for transmission of motion from motor to a shaft
« Reply #1 on: April 12, 2017, 05:24:33 AM »
maybe he meant to say a key way any way a bolt through should work a bit rough and ready all relevant to power you intend to transmit tools you have etc
