Author Topic: peizo film sensor as touch which?  (Read 1690 times)
Offline dmehlingTopic starter
« on: August 28, 2007, 04:03:04 PM »
I ran across the following peizo electric film vibration sensor and I wondered if it would work well as a touch sensor?
http://www.parallax.com/detail.asp?product_id=605-00004
Also the instructions contained a precaution warning about high voltages and that the signal going to the I/O pins should be clamped, buffered, or filtered in order to maintain proper voltage or current levels.  Should I be concerned about that since I will be connecting it to a microcontroller with a 12 V power supply and a voltage regulator?
Offline HDL_CinC_Dragon
Re: peizo film sensor as touch which?
« Reply #1 on: August 28, 2007, 08:06:31 PM »
well when crystal are squeezed they emit voltage... thats why when you apply voltage, they oscillate.
So I guess you could use it as a touch sensor... even better it could probably measure how hard it was hit based on how many volts are commin out of it...
United States Marine Corps
Infantry
Returns to society: 2014JAN11
