2
Author Topic: Motor for spinning wheel  (Read 665 times)
Offline singerepTopic starter
« on: August 17, 2017, 01:49:06 PM »
Hello! Can anyone recommend a inexpensive motor to be used to continually spin a medium-lightweight wheel about 6 inches in diameter at at least 4000 rpm (preferably more).
Thanks!
Offline digibloke12
Re: Motor for spinning wheel
« Reply #1 on: September 10, 2017, 05:36:17 PM »
Hi!
You can check out Power Jack Motion's Electric Motor range. They do have a wide, interesting line of products, so your choices won't be limited. Aside from RPM, there are a lot of considerations you need to do in order to select the right motor; the site's brief discussion on selecting such can provide you an overview of what's going to be the best motor for your needs.
Hope this helps!
