Author Topic: [advertisement] New Cascading X-Rail Slide Kit!  (Read 1312 times)
Offline ServoCityTopic starter
  • Helpful? 18
« on: October 13, 2017, 10:28:39 AM »
The NEW Cascading X-Rail Slide Kit provides all the mechanical pieces necessary to build a winch-driven extendable arm.  Fasten a motor or HS-785HB servo to the first stage of the slide kit and spool up the provided synthetic cable to get up to 34.5" of arm extension!  This kit uses bearings throughout - each stage is supported by 4 Mini V-Wheels that lock into the chamfered guides of the X-Rail.  The synthetic cable is routed over ultra smooth v-bearings so the torque provided by the servo or motor can be transformed into linear thrust rather than lost due to friction.  The arm, at full extension is rated for a 2lb load; perfect for adding a gripper or grapple hook.
https://www.servocity.com/cascading-x-rail-slide-kit
[youtube]https://youtu.be/4cRRocKzu_A[/youtube]
[youtube]https://youtu.be/5XUkRJD3CnM[/youtube]
