Author Topic: two files sharing variables  (Read 2125 times)
Offline AdminTopic starter
« on: August 29, 2007, 04:26:42 PM »
I have two different .c files compiled together and I want them to share a variable. What is the best way to do this? A header file?
Offline h3ro
Re: two files sharing variables
« Reply #1 on: August 29, 2007, 04:31:59 PM »
You can include .c files, no need to create a separate .h file (But it would be a bit cleaner)
Also, you can store them in a .txt file and have the .c files read from that file. Thats probably the best options if thats possible.
« Reply #2 on: August 29, 2007, 04:34:32 PM »
So the makefile requires me to specify all the .c files together . . . so I assumed they would work together but they arent . . .
« Reply #3 on: August 29, 2007, 05:01:42 PM »
Hmmmm so I figured out the problem . . .
Apparently if you add .c files as a dependency to a makefile to compile together, they DO NOT LINK variables. Only functions . . .
So I took your suggestion and did an #include. This fixed it and now the .c files share variables.
Argggg . . . is this a bug with the makefile thingy?
Offline JesseWelling
  • Only You Can Build A Robot!
« Reply #4 on: August 29, 2007, 06:48:16 PM »
I assume you mean a global variable used in two different .c files?
You need to use the keyword 'extern' meaning that the same named variable is in some other scope (non file scope)
http://www.faqs.org/docs/learnc/x784.html
You can also extern (used as a verb here ;) ) functions that are not declared in a .h file.
« Last Edit: August 29, 2007, 06:52:14 PM by JesseWelling »
Last post December 19, 2008, 10:05:58 AM
Last post November 26, 2011, 12:26:04 PM
by ruben301088
Last post September 02, 2012, 02:23:04 AM
by ankitbansal
Last post May 03, 2013, 10:09:12 AM
by ROBOT420
