Author Topic: Desperately need HELP on gearing !  (Read 565 times)
Offline ProStreetTopic starter
« on: May 30, 2019, 01:23:45 PM »
This is my first attempt do  anything like this.
Looking for help without re-inventing the wheel.
My problem is that I need some sort of way to reduce the output RPM out to a devise.
I believe I will need some sort of adjustable frame to hold the gearing of different and multiple diameters.
I think I need the final output to be as low as 1/4 to 1 RPM (extremely slow)
It must have an easy way to add and subtract gears, move axels and gears to achieve my RPM goal.
It needs an input shaft for the motor and a output shaft to rotate (slowly) my device.
If someone could PLEASE send me a link to what I'm trying to achieve.
Any and all suggestions wild be very appreciated.
Thank You in advance.
Jerome
