Author Topic: Torque needed to twist off a bottle cap  (Read 10555 times)
Offline airman00Topic starter
« on: August 31, 2007, 05:09:21 PM »
I need to know the amount of torque needed to twist off a bottle cap from a soda bottle. Can anyone guess an approximate torque? Or where I can find that out from?
Thank you,
Eric
Offline ed1380
Re: Torque needed to twist off a bottle cap
« Reply #1 on: August 31, 2007, 05:30:22 PM »
securly mount a 1ft long rod to teh cap. and lay the bottle down, with teh cap  hanging off of a table, and then start adding  weights at the end of the rod.
once it twists off, you know how many ft/lb you need
Offline Gertlex
  • Helpful? 24
« Reply #2 on: September 01, 2007, 07:36:58 AM »
Account for the torque provided by the rod too, of course.
Unless you mount the center of the rod to the cap, then it cancels itself out.
I
Offline ed1380
« Reply #3 on: September 01, 2007, 03:46:30 PM »
yeah didn't think of that.
« Reply #4 on: September 09, 2007, 02:42:49 PM »
FYI, its:
torque = .5 * (weight of rod) * (length of rod) + (weight of object) * (length of rod)
Offline SomeSaba
« Reply #5 on: September 23, 2007, 11:39:22 PM »
FYI, its:
I *always* been confused on that:
Torque= rF (disntace * force)
Weight is a force, but to calc weight dont u have to say W = mg (mass and grav. acc. 9.8m/s^2)!?!?
So if u mass it on a scale thats the mass right?? so u have to multiply it dont u?
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
« Reply #6 on: September 23, 2007, 11:54:25 PM »
Wrong, you can scale only the weight, not the mass. Then you can calculate the mass using the formula you mentioned.
« Reply #7 on: September 24, 2007, 04:41:59 AM »
Weight is mass times gravity.
Weight is a force, while mass is not.
Offline dcole07
« Reply #8 on: September 24, 2007, 12:32:29 PM »
Unless he uses one of those mass-less rods!  ;D
Offline MeKaDa
« Reply #9 on: September 25, 2007, 06:04:13 AM »
Couldnt he just use a torque wrench,just find a way to fit the cap in there.
Offline Tsukubadaisei
« Reply #10 on: September 26, 2007, 03:01:22 AM »
when calculating the torque the direction is also important.
T=rf is wrong
Correct
T=RxF (cross product)
  =R*F*sin(angle) (absolute value)
  =det [i     j     k ]
          [Fx  Fy   Fz]
          [Rx  Ry  Ry]
where det is the determinant of the matrix.
« Last Edit: September 27, 2007, 06:39:26 AM by Tsukubadaisei »
Offline ed1380
« Reply #11 on: September 26, 2007, 06:14:15 PM »
AFAIK torgue wrenches are made for high amounts of toruqe
Offline Robotboy86
« Reply #12 on: September 27, 2007, 03:06:56 PM »
..not to be mean or anything..
BUT:
Just use a big servo and call it a day.  Its going to be less then friction that human skin can withtake..  as such, its not going to be a lot.
my guess is under 40ft/lbs.
Probaly far under.
« Reply #13 on: September 27, 2007, 04:37:03 PM »
I think you meant 40lb*ft ;D
btw, thats a lot!
Im guessing more like 5lbft . . .
Offline Robotboy86
« Reply #14 on: September 28, 2007, 11:21:09 AM »
ya I did mean that lol thanks Admin.
I agree its also FAR under 40, 40 would probaly shatter the glass while trying to twist..  lol
