Author Topic: solarengien  (Read 1991 times)
Offline ErVaKTopic starter
solarengien
« on: September 01, 2007, 10:02:21 PM »
hi im making a sloar engin and was wondiring if there is any way i could eliminate the voltage triger asspect?
ErVaK
Re: solarengine
« Reply #1 on: September 04, 2007, 09:25:20 AM »
its spelled 'solar engine' :P
why? you need something to trigger on/off for a solar engine to work.
Re: solarengien
« Reply #2 on: September 08, 2007, 04:54:49 AM »
ok thanks :p
Yes
and sorry been so long been away for a bit
ErVaK
Offline paulstreats
Re: solarengien
« Reply #3 on: September 08, 2007, 05:38:10 AM »
do you mean to like charge a capacitor with a solar panel, then use a voltage detector to trigger a release from the capacitor into either a battery or motor?
If so, the voltage detector ensures that there is enough power to drive a motor, usually there isnt enough power coming directly from a small solar panel to drive a motor, so the power is stored up in a capacitor until it reaches a level that can drive the motor. If you cant get the relevant voltage detector (samples maxim-ic) you may be able to do something with transistors.
