Electronics > Electronics
solarengien
(1/1)
ErVaK:
hi im making a sloar engin and was wondiring if there is any way i could eliminate the voltage triger asspect?
Admin:
its spelled 'solar engine' :P
--- Quote ---if there is any way i could eliminate the voltage triger asspect?
--- End quote ---
why? you need something to trigger on/off for a solar engine to work.
ErVaK:
--- Quote from: Admin on September 04, 2007, 09:25:20 AM ---its spelled 'solar engine' :P
ok thanks :p
--- End quote ---
--- End quote ---
Yes
and sorry been so long been away for a bit
paulstreats:
do you mean to like charge a capacitor with a solar panel, then use a voltage detector to trigger a release from the capacitor into either a battery or motor?
If so, the voltage detector ensures that there is enough power to drive a motor, usually there isnt enough power coming directly from a small solar panel to drive a motor, so the power is stored up in a capacitor until it reaches a level that can drive the motor. If you cant get the relevant voltage detector (samples maxim-ic) you may be able to do something with transistors.
Navigation
