Author Topic: MCU Browning Out  (Read 1816 times)
Offline frank26080115Topic starter
MCU Browning Out
« on: September 03, 2007, 12:01:58 AM »
Well the motors would go for a split second, and the program resets, I already have a 22uF cap across the power (unregulated 9v) and ground, and a 0.1uF between the ground and the 5v, what can I do to stop the resets?
Re: MCU Browning Out
« Reply #1 on: September 04, 2007, 09:20:03 AM »
Is the 9V battery your only power source?
If so, that is the problem. They cannot supply enough juice to power motors, so you will need to get another separate battery. I recommend a 6V NiMH type battery that is at least 1500mAh.
http://www.societyofrobots.com/robot_parts_list_battery.shtml
« Reply #2 on: September 04, 2007, 09:30:50 PM »
Thanks, I actually got a 6V 700mAh Ni-Cd battery + charger recently, for $3 and it's new!
