Buy an Axon, Axon II, or Axon Mote and build a great robot, while helping to support SoR.
class Cell attr_reader :value, :possible_values def initialize (n) @possible_values = Array.new(n) { |i| i + 1 } @value = nil end def deep_copy Marshal::load(Marshal.dump(self)) end def is (value) @value = value @possible_values.clear end def remove_possible (number) temp = @possible_values.delete number throw :violation if @possible_values.length < 1 && @value == nil return temp end def to_s puts "value: #{value}" puts "possible: #{possible_values}" endendclass Region @cells_contained attr_reader :cells_contained def initialize @cells_contained = Array.new end def add_cell (cell) @cells_contained << cell end def cell_is_member? (cell) @cells_contained.include? cell end def remove_value (value) count = 0 @cells_contained.each { |cell| count += 1 if cell.remove_possible value } count end def remove_value_plus (value) the_cells = Array.new count = 0 @cells_contained.each do |cell| if cell.remove_possible value count += 1 the_cells << cell end end return count, the_cells end def remove_value_plus_plus (value, keep_cell) the_cells = Array.new count = 0 @cells_contained.each do |cell| unless keep_cell == cell if cell.remove_possible value count += 1 the_cells << cell end end end return count, the_cells end def find_forced_values (n) count = Array.new(n, 0) @cells_contained.each do |cell| cell.possible_values.each { |value| count[value - 1] += 1 } end i = 1 count.each do |value| if value == 1 @cells_contained.each do |cell| if cell.possible_values.include? i return cell, i end end end i += 1 end return nil, nil end def any_nils? @cells_contained.each { |cell| return true if cell == nil } nil end def to_s puts @cells_contained endendclass Snapshot attr_reader :cells, :remaining_count, :index def initialize (cells, remaining_count, index, cells_solved_count, regions, n) @cells = Array.new @regions = Array.new(3*n) {Region.new} #find which regions the current cell is in. #put the new cell in those same regions cells.each do |cell| @cells << new_cell = cell.deep_copy i = 0 regions.each do |region| if region.cell_is_member? cell @regions[i].add_cell new_cell #puts "region: #{i}\t#{@cells.index(new_cell)+1}" end i += 1 end end @remaining_count = Array.new(remaining_count) @index = index @remaining_psbl = Array.new(@cells[index].possible_values) #@remaining_psbl = @cells[index].possible_values @cells_solved_count = cells_solved_count end def best_guess max = 0 guess = nil @remaining_psbl.each do |value| if @remaining_count[value - 1] > max max = @remaining_count[value - 1] guess = value end end guess end def last_choice? @remaining_psbl.length <= 1 end def rollback @remaining_psbl.delete best_guess return @cells, @remaining_count, @index, @cells_solved_count, @regions end def to_s puts "remaining count: ", @remaining_count << "\nindex: " << @index endendclass Board @n @nxn @cells @remaining_count @regions @cells_solved_count @number_of_assignments_made attr_reader :n, :cells, :regions, :remaining_count, :snapshots, :number_of_assignments_made def initialize (n) @n = n @nxn = n * n @cells = Array.new(@nxn) { Cell.new n } @remaining_count = Array.new(@n, @nxn) @regions = Array.new(@n * 3) { Region.new } @cells_solved_count = 0 @snapshots = Array.new @number_of_assignments_made = 1 end def solved? @cells_solved_count >= @nxn end def cell_is (index, value) @cells[index].possible_values.each do |decrement_value| @remaining_count[decrement_value - 1] -= 1 end @cells[index].is value ac3 index, value @cells_solved_count += 1 @number_of_assignments_made += 1 end def next_cell_to_solve min = @n min_cell_index = nil running_index = 0 degree_max = 0 @cells.each do |cell| unless cell.value if cell.possible_values.length == 1 return running_index elsif cell.possible_values.length < min min_cell_index = running_index min = cell.possible_values.length elsif cell.possible_values.length == min cell.possible_values.each do |value| if @remaining_count[value - 1] > degree_max degree_max = @remaining_count[value - 1] min_cell_index = running_index end end end end running_index += 1 end min_cell_index end def take_snapshot (index) @snapshots.push(Snapshot.new(@cells, @remaining_count, index, @cells_solved_count, @regions, @n)) end def has_snapshot? (index) unless @snapshots.empty? return index == @snapshots.last.index end false end def rollback @snapshots.pop if @snapshots.last.last_choice? @cells, @remaining_count, index, @cells_solved_count, @regions = @snapshots.last.rollback #pop the snapshot if it is the last guess #@snapshots.pop if @snapshots.last.last_choice? index end def next_guess (index) unless @snapshots.empty? return @snapshots.last.best_guess if @snapshots.last.index == index end max = 0 guess = nil @cells[index].possible_values.each do |value| if @remaining_count[value - 1] > max max = @remaining_count[value - 1] guess = value end end guess end def find_forced @regions.each do |region| cell, value = region.find_forced_values @n if cell return @cells.index(cell), value end end return nil, nil end def possibilities_remaining (index) @cells[index].possible_values.length end def ac3 (index, value) queue = Array.new @regions.each do |region| if region.cell_is_member? @cells[index] count, modified_cells = region.remove_value_plus value @remaining_count[value - 1] -= count unless count == 0 queue = queue + modified_cells end end end super_pp #puts "Moddified_cells: #{queue}" queue.each do |d_cell| puts "index: #{cells.index(d_cell)}" end until queue.empty? cell = queue.shift if cell.possible_values.length == 1 value = cell.possible_values.first @regions.each do |region| if region.cell_is_member? cell count, modified_cells = region.remove_value_plus_plus value, cell @remaining_count[value - 1] -= count unless count == 0 queue = queue + modified_cells end end end end super_pp end end def remove_inconsistant (checkcell, rootcell) if rootcell.possible_values.length == 1 if checkcell.remove_possible(rootcell.possible_values.first) #decement count of rootcell.possible_values.first #return true end end nil end def neighbors (index) queue= Array.new @regions.each do |region| if region.cell_is_member? @cells[index] queue | region.cells_contained end end #queue.flatten! #queue.uniq! queue.delete @cells[index] queue.each do |checkcell| checkcell << @cells[index] end queue end def add_cell_to_region (index, region) @regions[region].add_cell @cells[index] #puts "#{index+1}\t#{region}" end def to_s i = 1 @cells.each do |cell| if cell.value then print cell.value else print '?' end if i % @n == 0 then puts else print ' ' end i = i.next end end def super_pp display = Array.new(35) { String.new } col = row = 0 @cells.each do |cell| if value = cell.value display[row] << " " display[row+1] << " #{value} " display[row+2] << " " else (1..9).each do |value| if value > 6 disp_row = row + 2 elsif value > 3 disp_row = row + 1 else disp_row = row end if cell.possible_values.include? value display[disp_row] << "x" else display[disp_row] << " " end end end display[row] << "|" display[row+1] << "|" display[row+2] << "|" col += 4 if col > 35 col = 0 display[row+3] ="-------------------------------------" row += 4 end end display.each {|x| puts x} puts "Number of assignments made: #{number_of_assignments_made}" endenddef create_puzzle (board, known_file, region_file) contents = IO.read region_file #strip off the other junk so you only have a space seperated list of numbers contents.gsub!(/\n/, ' ') contents.gsub!(/\)|\(/, '') n = board.n (0..n*n - 1).each do |i| board.add_cell_to_region(i, i / n) board.add_cell_to_region(i, n + (i % n)) end n = board.n region_index = 2 * n contents = IO.read region_file contents.each_line do |line| line.gsub(/\)|\(/, '').chomp.each(' ') do |cell_index| board.add_cell_to_region(cell_index.to_i - 1, region_index) end region_index += 1 end contents = IO.read known_file contents.gsub!(/\n/, '') cell = 0 contents.each(' ') do |current| board.cell_is(cell, current.to_i) unless current.strip == '?' cell += 1 end boardenddef solve_puzzle (board) cell_index = nil until board.solved? do catch :violation do until board.solved? do still_easy_stuff = true while still_easy_stuff && !board.solved? cell_index, value = board.find_forced while cell_index && !board.solved? puts "index: #{cell_index} :forced choice" board.cell_is(cell_index, value) cell_index, value = board.find_forced end cell_index = board.next_cell_to_solve while !board.solved? &&board.cells[cell_index].possible_values.length == 1 puts "index: #{cell_index} :only possibility" board.cell_is(cell_index, board.next_guess(cell_index)) cell_index = board.next_cell_to_solve end temp_index, temp_value = board.find_forced if !board.solved? unless board.cells[cell_index].possible_values.length == 1 || temp_index still_easy_stuff = false end end end if !board.solved? && board.cells[cell_index].possible_values.length > 1 #take a snapshot unless board.has_snapshot? cell_index board.take_snapshot cell_index puts "snapshot pushed on index #{cell_index}" end #then pick a value to guess guess = board.next_guess cell_index puts "guess value: #{guess} at index: #{cell_index} :guessed choice" #then assign that value board.cell_is(cell_index, guess) #then run ac3 end end end unless board.solved? puts "a violation has occurred." board.super_pp cell_index = board.rollback puts "number of snapshots: #{board.snapshots.length}" puts "roll back on index #{cell_index}" end #next cell to solve needs to be the one returned from rollback end #puts boardendsolve_puzzle(create_puzzle(Board.new(9), 'diabol_problem.dat', 'diabol_region.dat'))
? ? 5 4 ? 9 8 ? ? 2 ? ? ? ? ? ? ? ? 6 ? ? ? 5 1 ? ? 7 ? ? 7 ? ? ? ? ? ? ? ? ? 3 ? ? ? ? ? ? ? ? ? 1 ? 4 ? ? 7 4 ? ? 3 ? ? ? 6 ? ? ? ? ? ? ? ? ? ? ? 1 8 ? ? ? ? ?
((1 2 3 4 10 11 12 13 21)(5 6 7 8 9 15 16 17 25)(14 23 24 33 34 35 43 44 52)(18 26 27 36 45 53 54 62 63)(19 20 28 29 37 46 55 56 64)(22 31 32 40 41 42 50 51 60)(30 38 39 47 48 49 58 59 68)(57 65 66 67 73 74 75 76 77)(61 69 70 71 72 78 79 80 81))
