Author Topic: advice on milling fiberglass?  (Read 3963 times)
Offline AdminTopic starter
« on: September 10, 2007, 02:24:05 PM »
I plan to do some milling of fiberglass plates, but somehow I feel its not going to work like plastics or metals . . .
I googled around for tips on milling fiberglass with no luck.
Anyone with suggestions? Preferred endmill type? Feed and tool speed? Safety notes?
As a side note . . . what is the density and tensile strength of fiberglass? Was unable to find it with the previously mentioned links . . .
http://www.societyofrobots.com/robotforum/index.php?topic=1758.0
Offline hgordon
  • Helpful? 7
Re: advice on milling fiberglass?
« Reply #1 on: September 10, 2007, 03:46:12 PM »
This might be a good starting point ...
    http://www.pcbmilling.com/
Also, wear a mask.
Surveyor Corporation
  www.surveyor.com
Offline awally88
« Reply #2 on: September 10, 2007, 11:28:54 PM »
If you don't go really slowly with it you can rip chunks out of what you're doing.  Also don't breath the dust -  when I've done other, non robotic, stuff with fibreglass I've always found that its a good idea to have a vacuum cleaner next to me as the dust as well as being pretty bad for you itches like all hell.
« Reply #3 on: September 11, 2007, 08:09:23 AM »
Ive worked with carbon fiber in the past, I figured Id treat fiberglass the same.
I already put in an order for a good face mask and a 5 flute endmill (Im guessing that will work better for it?).
Offline akres15
« Reply #4 on: September 11, 2007, 03:26:28 PM »
i used a drill press for fiberglass
and cut it with a hacksaw
« Reply #5 on: September 12, 2007, 07:12:24 AM »
I couldnt find anything about fiberglass on that site . . .
http://www.pcbmilling.com/Site%20Map.htm
Offline JonHylands
« Reply #6 on: September 12, 2007, 07:23:06 AM »
PCB's are made from fiberglass...
- Jon
Offline Robotboy86
« Reply #7 on: September 27, 2007, 03:30:39 PM »
So what was the result? How did milling go?
« Reply #8 on: September 27, 2007, 04:34:34 PM »
Havent had the opportunity.
You see, I work for the gov't, and sometimes they say 'stop ordering stuff' without giving a reason. Three plus months without being allowed to order stuff (such as the fiberglass) really slows down my work . . . but thats gov't work for ya! ;D
Ill let you guys know how it goes when I get a chance . . .
Last post December 03, 2007, 01:44:12 PM
by Robotboy86
Last post January 15, 2008, 09:15:57 PM
by airman00
need advice.
Started by jakx12 Misc
Last post May 29, 2009, 05:13:44 AM
by jakx12
Last post February 15, 2010, 03:17:59 AM
