Author Topic: Acrylic Glass (Polymethyl methacrylate) as a building material?  (Read 2673 times)
Offline MadMaxTopic starter
« on: September 12, 2007, 03:11:59 PM »
I was looking at the pricing of HDPE, and it was quite expensive because it isn't available to 'small buyers'. Most companies (In Holland, that's where I live) will only deliver large ammounts to companies. I found a site that selled HDPE in sheets of 1m2. However, this is too expensive.
So I looked a little further on that site and also found sheets of Acrylic Glass (or: Plexiglass/Polymethyl methacrylate/PMMA) in sheets of 50cm * 50cm * 4mm. I was wondering if it is a good building material. So, for your convenience, information about the product from wikipedia :):
Molecular formula                (C5O2H8)n
Molar mass                        varies
Density                        1.19 g/cm?
Melting point                        130-140 ?C (265-285 ?F)
Boiling point                        200.0 ?C (392 ?F)
Breaking index(translated from dutch): 1,489 n
« Last Edit: September 12, 2007, 03:26:05 PM by MadMax »
Offline h3ro
Re: Acrylic Glass (Polymethyl methacrylate) as a building material?
« Reply #1 on: September 13, 2007, 02:36:33 AM »
I use that on my robot. But its my first robot, so it might be a stupid choice.
Its fairly easy to work with. I only used a hand saw and a small dremel.
If you look for a place where they make/fixes windows for cars, you can probably get some for free. I did that :)
Offline Rebelgium
« Reply #2 on: September 13, 2007, 05:55:43 AM »
Can't you find a hardware store in your vicinity? There's a "stock americain" near where I live, and they sell that for a good price...
Ofcourse getting it free like h3ro said is much better ;)
The material itself is ideal to make robots. It's beautiful, easy to work with, sturdy,...
The only small downside is that it's pretty easily scratchable, and when it's damaged you can always see it from whatever angle you look at it.
orgcrime.net
Offline JonHylands
« Reply #3 on: September 13, 2007, 08:09:29 AM »
If you've got a store that sells kitchen stuff (Walmart or something like that), you can buy plastic breadboards from them, which are basically solid chunks of HDPE...
- Jon
Offline Brandon121233
« Reply #4 on: September 13, 2007, 09:00:34 PM »
I would use polycarbonate (Lexan) instead because it has about 100X the durability of Acrylic.
        —Thomas Edison
Offline JonHylands
« Reply #5 on: September 14, 2007, 05:50:38 AM »
The problem with Lexan is it is very brittle...
- Jon
Last post October 31, 2008, 04:23:30 AM
Last post November 27, 2008, 08:35:52 PM
by jamort
Last post January 16, 2009, 03:48:11 PM
by Xerox23
Last post July 06, 2010, 11:33:24 AM
by Asellith
