Author Topic: Getting torque out of 3DCV  (Read 1990 times)
Offline MeKaDaTopic starter
« on: September 14, 2007, 12:36:14 PM »
A school project limits my energy sources to 2x Duracell AA batteries(1.5V each). I need to pull a wheeled prototype weighting around 1kg. I'll need to get up a 15deg slope. Now the best stall torque i could find for 3V is 15cm-g which, unless my math is wrong, isnt enough. Anyone knows of a better motor or if there's a way to raise my voltage? Unless im mistaken, i cant use a transformer on DC...
Offline Rebelgium
Re: Getting torque out of 3DCV
« Reply #1 on: September 14, 2007, 12:54:37 PM »
You can't use transformers on DC, but you can use DC-DC switching to make the voltage higher.
And you could also use those small 3VDC FA130 motors, use a motor (with gearbox ofcourse) for every wheel. So you can use four motors with gearboxes for your robot without having to make the voltage higher...
That should do it.
orgcrime.net
Offline hgordon
  • Helpful? 7
« Reply #2 on: September 14, 2007, 02:13:29 PM »
Raising the voltage probably won't help you, since you're still limited by the output current of the AA's.  Look for the highest gear ratio you can find - that's the way to get more torque.
These motors should be adequate -
    http://www.solarbotics.com/products/index.php?scdfa-250100084-viewDetail-productzq31047zq4categoryzq37=true
They should be able to run at 3V, and are rated at 30.7 oz-in at 5V, which would be equivalent to 2210 gm-cm at 5V or 1326 gm-cm at 3V (1 oz-in = 72 gm-cm).  Also, use the smallest drive wheels you can find to maximize your torque.
Surveyor Corporation
  www.surveyor.com
Offline Rebelgium
« Reply #3 on: September 14, 2007, 02:27:23 PM »
Unless he's at the maximum current of the AA's, that's not true.
Raising the voltage will help.
And yes ofcourse, how could I forget to mention the most obvious  ::) ;) , small wheels and high gear ratios.
The higher the gear ratio: more torque, less speed.
orgcrime.net
Offline paulstreats
« Reply #4 on: September 14, 2007, 05:29:39 PM »
the tamiya twin motor gear box by pololu can gear down to 501:1 ratio, its cheap and includes motors which can operate at 3v, i have a spare one and ive just tested it at 3v. There are different sized wheels that you can buy at the same time, obviously the larger ones will reduce the effect of the gearing slightly but move faster.
« Reply #5 on: September 15, 2007, 01:07:38 PM »
This is a tutorial I wrote with a calculator to answer this exact type of question . . .
http://www.societyofrobots.com/mechanics_dynamics.shtml
Just plug in your numbers and it will tell you if your motor is strong enough.
Now you didnt mention speed . . . so you could just gear down your motor a lot. Your robot will be very slow, but have high torque:
http://www.societyofrobots.com/mechanics_gears.shtml
Last post July 13, 2007, 02:12:05 PM
by sotu
servo torque
Started by crarm Misc
Last post January 10, 2009, 02:11:19 PM
by ArcMan
Last post June 18, 2009, 06:01:47 PM
by Hawaii00000
Last post March 02, 2010, 12:10:14 AM
by SmAsH
