Software > Software
Could you program a robot to beat one of these? I am pretty sure you could!
(1/1)
NOOBinDistress:
mode=related&search=
airman00:
possible  for sure
all you need is a solenoid to push the button and a very good camera. ( and a whole lotta programming and hardware to connect the two properly)
lol
also, how would you test it? ( buy your own stacker???)
NOOBinDistress:
Either that or use a lot of coins!
awally88:
You could take a video of it and get the speeds of the moving blocks and then program a simple program to simulate this on the screen.  It wouldn't be 100% but you could tweak and get pretty close to the exact simulations.
However if a store person sees you with a camera and solenoid setup on the machine they are probably likely to get a little bit stroppy at you! So if you were to make one you would need to make it inconspicuous eg have a camera mounted in glasses which interact with a small solenoid device wirelessly or with a limited number of wires so it can be easily hidden!
Navigation
