Author Topic: image files question  (Read 2117 times)
Offline octagonxTopic starter
« on: September 17, 2007, 12:56:20 AM »
Is there a program that can view image files as an array of bits?
Offline crossroads1946
Re: image files question
« Reply #1 on: September 17, 2007, 12:06:30 PM »
Technically, you could do it with a text editor, although you'd probably loose the non-printable characters. It really depends on what the format is. You need to know how many bits are used per pixel, if it stores alpha information or any other info, what kind of compression schemes it uses, etc... What is the image format?
Offline dunk
« Reply #2 on: September 17, 2007, 01:00:38 PM »
hi octagonx,
most image formats (png or jpeg for example) have some sort of data compression going on so looking at the raw contents doesn't tell you much.
most programming languages have libraries to handle the conversion into usable data for you.
you'll need to search a bit to find one with documentation that you can use with whatever language you are using.
« Reply #3 on: September 18, 2007, 11:30:48 PM »
i've tried opening .bmp files using text editor.  And i think, it does resembles how the image looks like. But what I want is to view each character as a value (numbers, hex etc) so i can at perform mathematical operations on them. Thanks for the replies, dunk, crossroads.
Offline JesseWelling
  • Only You Can Build A Robot!
« Reply #4 on: September 19, 2007, 12:22:51 AM »
« Reply #5 on: September 19, 2007, 11:15:50 PM »
Last post June 09, 2008, 09:35:25 PM
by vidam
Last post October 02, 2008, 10:36:09 AM
by superchiku
Last post November 27, 2008, 05:35:30 PM
by Canabots
Last post December 19, 2008, 10:05:58 AM
