Author Topic: Moving along the edge  (Read 1804 times)
Offline teekayTopic starter
« on: September 25, 2007, 08:35:25 AM »
Hello,
Does anyone have an idea to make a robot move along an edge (of a table etc.) without using any image processing technique..?
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
Re: Moving along the edge
« Reply #1 on: September 25, 2007, 09:37:13 AM »
Offline snow
« Reply #2 on: September 25, 2007, 03:15:47 PM »
Two IR sensors: [ROBOT]--[SENSOR1]--[SENSOR2].
If SENSOR1 is on AND SENSOR2 is off you are going ok.
If both on you must turn toward the edge.
If both off you must turn away from the edge.
If SENSOR1 is off AND SENSOR2 is on your robot has already fallen down and broken the sensor holder :)
« Reply #3 on: September 27, 2007, 04:56:17 PM »
As snow said, you just need a sensor that can detect where the table edge is.
Try this:
http://www.societyofrobots.com/sensors_sharpirrange.shtml
and look up line following robots (an edge is also a line)
Last post January 16, 2009, 09:20:29 PM
by Jdog
Last post June 28, 2009, 07:07:36 AM
Last post September 14, 2009, 05:27:05 PM
by Pierre
Last post November 11, 2012, 09:13:10 AM
