Author Topic: Torque  (Read 2229 times)
Offline MadMaxTopic starter
Torque
« on: September 28, 2007, 05:42:57 PM »
This might be one of the easiest questions ever asked. I'm doing some research on buying 12 servo's, wich is quite expensive for me at the moment. So I was looking around, and the cheapest I've found (Hitec HS-311) have a Torque of "42 oz/in (3.0 kg/cm)". What does this mean exactly? How can I check if it can lift 6N?
Offline ed1380
Re: Torque
« Reply #1 on: September 28, 2007, 05:55:29 PM »
reall all of this http://www.societyofrobots.com/mechanics_gears.shtml
hell. why not read all of this and every link shown http://www.societyofrobots.com/robot_tutorial.shtml
Re: Torque
« Reply #2 on: September 29, 2007, 03:29:05 AM »
I've read that. But my question was what 3.0kg/cm meant. So, why are the centimeters there, is it the gear diameter? That's the part I wasn't able to understand
Re: Torque
« Reply #3 on: September 29, 2007, 07:04:44 AM »
read this:
http://www.societyofrobots.com/mechanics_statics.shtml
so that number is torque, meaning the amount of force it can give out with a certain length beam.
sorta like a crowbar, where the length affects force.
so 42 oz * in means it can give a force (lift a weight) of 42 oz for an inch long beam. or 21 oz for a 2 inch long beam. etc.
if your robot arm was 42 inches long, it could lift 1 oz (not accounting for lifting itself).
Re: Torque
« Reply #4 on: September 29, 2007, 08:39:26 AM »
a'ight... Thank you :)
